So I have had a time trying to get this setup. Had to use the c adapter. Now there is no heat blowing during any stage of the test. Original configuration to now is W2 to W1, G to C, O to O/B, Y to Y1, R to Rc. I am so lost
how did you wire the wyze and what does the furnace/ heat pump side of the wiring look like?
Yes, need pics of both sides of the colored wires. You are in good hands with @speadie.
