No Delay Timer For Selected Sensors On HMS
Allow Setting Certain Sensors (ie: Contact Sensors Installed On Windows, Back Door, Shed Door, Attic Access, etc. ) To Be Set Up To Instantly Trigger The HMS To Sound The Siren (Set Off The Alarm) (No Delay Timer).
@mkgyver76 If you want the alarm to sound immediately when an entry sensor is opened, under Exit & Entry settings change the entry delay time to zero seconds.
I would like to have window sensors, shed sensors, and attic sensors sound the alarm immediately and door sensors utilize the delay timer.
| StopICU33 Forum Moderator
July 4 |
Search the Wish List for this…I’m quite certain a posting has already been made.
