No 2 way audio option
I just got 2 v4 cans today and for some reason I don’t have the option available for 2 way audio… It’s also missing on my v3 pro cam but on the regular v3 it’s there… I’ve reinstalled the app… Reinstalled all cams Updated software, and cleared cache and the option still isn’t there
Tap the live view stream once, tap the microphone icon at the bottom of the live view area. Both the mic and speaker icons will turn solid white. If this is your 1st time, you’ll need to give the app permission to record or something like that.
Thanks for reminding me about permissions. That’s one thing I didn’t check and somehow the permissions for mic use was turned off… Not sure how that happened
No prob. Permissions gets me every now and then too. :+1:
