Night vision IR lights
Found another bug I keep running into an issue with. I have one v2 camera mounted outside in a mount with a clear plastic sheet in the front. Because if this I have to have the IR lights Turned off.
I have auto night vision set on “auto” and have the IR lights turned off. The only problem I have is if I turn off the camera, I noticed when the camera powers back up the IR lights are on. When I go into the settings the IR lights are toggled off.
In order to fix this I have to toggle them “on” and then back off.
Someone else mentioned this in another thread.
I believe WYZE has acknowledged it.
