I’m wanting to put a Wyze cam in the rabbit barn but the wifi signal is weak! Any suggestions?
Add a router in AP mode or a dedicated WiFi extender to boost the signal strength. Most of the extenders are small and can be weatherized pretty easily if you have to have it outside.
Also, you will have to investigate a little to see why the signal is weak… Is it because of distance away from your router… Or if the barn has objects in or near the area that is creating strong interference.
I think that will help you determine your next steps…
