New router outdoor cams off line
My internet router died. After the one was setup my my outdoor cameras are offline. I tried syncing them with no luck. How do I get them back online?
Make sure you are using the same name and password that you used for the one you had , for your new router .
Is your outdoor base plugged into Ethernet ? If not you may have to plug it into Ethernet
Try removing the outdoor camera base, then set it up again and then try setting up cameras again
Keeping the same router name and PW is not a good option. I have spent 3 days getting 15 other items set up the new router. Also saw no way to change the router name. Seems to be hardwired in - Netgear R7000.
Outdoor base is connected via ethernet.
I wonder if uninstalling the wyze app and reinstalling it would work?
Thanks for the reply.
You can change , it I used to have a R6400
A quick search brought this up
@Newshound could probably help you out more
Can’t hurt give it a try
Many Many hanks for the Netgear KB article. I searched and didn’t find it. That is exactly what I needed 3 days ago. I save the site in case I ever need it again.
I fixed my issue by reinstalling the Wyze app but at first it came back up with the same cams installed but still off line, So I deleted all devices and started a new install of the base station and the 3 cams. Seems to be working fine now. Thanks for the help!!
Cool, glad ya got it all working
I believe it was coincidence this happened at same time you got a router. I bet you have the v2 cams huh. when you set them up with the new router did you by chance do a firmware update? bet you did huh?
