Now, every time I start the app, I get : “The latest version of the Wyze app is required to view one or more of your devices. Please update your Wyze app.”
AKAIK, 2.34.0.15 is the latest one.
Lousy coding again?!?
I have the latest version of the app and STILL getting this dumb prompt. Points to sloppy quality management, makes you wonder what protection is in place for sensitive items such as passowrds, credit card info etc.
Come on Wyze, not doing a test of your software before releasing it is pretty darned basic, especially for something as in-your-face-obvious as this (irritating) error, which pops up every single time you open the app… SHows you never tested it before posting. Amateur hour.
Same issue here. It gets annoying seeing it every time I open the app. Wyze doing what it does best. Sending out updates that ran in beta for a minimal time then release it to everyone. SMH:thinking:
Beats me. On iPhone 10 it doesn’t pop up. Can’t really blame Wyze if it’s product-specific: sounds like it must be an OS/product item. Warning pops up on iPad Pro Gen3…
They really need to completely overhaul the app, it’s not had a major overhaul and suffers from them having stuffed new items under an existing menu structrure. As a result it’s become unintuitive and cumbersone with a myriad of menus and submenus.
Same here. Running the latest iOS beta on an iPhone 13 Plus Max. The Wyze app from the App Store and the Wyze beta app are both giving me the same message. Believe they are both the same build number as well.
Yep, getting same message on iOS 15.6.1, iPad OS 15.6.1 and when running on M1 Studio Mac OS 12.5.1.
Would agree with others this is another example of poor quality control for software releases; the doorbell issues, v1 camera bricking, etc. Wyze needs to slow down releases and improve stability prior to releasing from beta.
I get the same thing on all of my iOS devices. All updated to the latest iOS, all running latest Wyze app. Still getting it as of this morning (8/31/22).
And I agree - Wyze needs to just halt putting new devices out and fix what they’ve got. Very poor quality control
I have the iPhone 10R. I am getting that *&^$# pop up as well. I am also seeing my cameras freeze whenever accessed. Its useless to have a frozen camera if you are trying to use them as a security measure. Mainly my doorbell does this. Now tell me Wyze, how can you see whos at the door if the camera is frozen? STABILITY Please!!!
