All worked for Wyze Beta on Android Q beta until the last 2.3.12 update,… Wyze broke with it’s beta update. NO new updates or changes occurred with Q beta at the time of the Wyze beta problem.
Hope that helps.
Hope that helps.
As a beta program member, how can I get the consumer version of the Wyze app as a workaround until beta is fixed without un-enrolling from the wyze beta program?
Where are you getting 2.2.38?
There is a site that stores all the earlier apk’s - ask tech support or a mod.
I’ve got one device on 2.38 and one on 3.12 (beta)
Thank you for the home page on/off function- this is a major usability feature!!! Keep up the great work.
