Have Starlink with its own router - have a network name & password - different than setup for all cameras - can’t find a way to make the change to new network -
This has been covered multiple times in the forum. Easiest way is to use the old SSID and Password for the new system. If you can’t you need to run setup on every device to change the wifi settings. Don’t delete them, just re-run setup.
Well, as you already know, using Starlink’s router, you can access it via the Starlink app. 1. Connect to the Starlink WiFi signal, 2. simply go in, change the WiFi/SSID name, and the password to what you want (the old one your Wyze cams are using), and 3. let it restart. Sometimes takes about 10 minutes, because it wants to rescan the sky. though it doesn’t need to.
I have Starlink. The Starlink gen 2 and gen 3 routers are mesh capable. You can add another node to convert it to a mesh system. Gen 2 is only WiFi 5, so might be smarter to connect a WiFi 6 or 6E or 7 to the Starlink router via Ethernet and use that Wyze old SSID and password on the new mesh instead of the Starlink router.
Thanks - your last point is appreciated - I wasn’t sure if I could do that - it is my preference - will give it a try - thanks very much!
Terry Lumb
[removed - personal info]
Life’s journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting “[removed - language]- what a ride”
Have a nice day!
I was not able to find “setup” on this or other drop downs - am I looking in the wrong area?
Terry Lumb
Have a nice day!
There is a setup button on the underside of the camera. Setting up the cam to connect to a different wifi name is like the time you initially setup the device.
