Need help how to start and stop a fan every 30min
Hi. I have to control an exhaust fan which is power by a wyze plug. I need to power on the fan every 30min for 3 min during the day. How to do it other then create a lot of schedules in auomation? Thanks in advance.
You need two rules, like these:
This is genius. I’m not sure I would’ve thought to use both “Has been on for” and “Has been off for” as triggers in alternating Automations. Strong work! :+1:
I was using a plug to control a dc portable cooler to ripen some pears. It kept getting too cold and freezing up. The short break kept things running
That’s a whale of a lot easer than an on / off command every 30 minutes!
I use a Plug to run Home & Away Profiles. via Google Location Sensing (since it can detect when the whole family leaves and won’t run it until everyone is gone).
Google sees we Leave —> Turn Plug off.
Inside Wyze Automations —> If Plug Turned off… turn on cameras, turn on motion detection, turn on notifications, turn off lights, lock door.
Google sees we come Home → Turn Plug On.
Inside Wyze Automations —> if Plug turns on … disable notifications on all cameras, unlock front door.
Then later…
Inside Wyze Automations —> If Plug has been on 15 minutes… → re-enable notifications, lock door.
This basically allows us to come home, get in the house, and try to stave off a bunch of notifications. But then turn them back on eventually because I would want them on later. Same idea of an on/off in a time period like the fan example… just a few more steps.
You can also spice that up and have a day vs. evening version of this that turns lights on after Sunset to greet you when you come home. I have my garage lights and front porch light brighten when I arrive at night (as an example).
You could use a temp sensor to react to this as well. I was doing this with my water softener in the garage when it got cold in January. I had a warming light setup that would turn the plug on if the temp sensor when below 35 or something. Worked great.
I then had a counter automation that would turn the plug off once it warmed up to 40 or something.
The automation game seems to be a bunch of point/counter-point automations. Whatever you turn on or automate, you have to turn it off or disable it.
I also create automations that Reset the whole setup to default in case things go wacky. Kind of like a MASTER silence on the whole house.
I don’t own any Wyze temp sensors. I use YoLink for all that. Could have done something in HomeAssistant with a Wyze/YoLink automation but my solution was easier.
It’s brilliantly simple and will work as long as the Internet connection back to Wyze’s servers (assuming they’re running correctly) is intact. Good stuff.
I really need to think about Home Assistant. I don’t know anything about it.
My needs seem to be met with Google/Alexa/Wyze. But I don’t know what I don’t know.. the new NBT filter for A.I. notifications is a game changer in terms of having to accommodate all the alerts/notifications. I have all outside cameras using it and I never get spammed. I only get events that I want… which seem to always be people or car related.
I wonder if could do any other fun stuff with the ecosystem if I had more granular control?
If you were to sell me on Home Assistant, what would be the #1 thing you would say about it?
Maybe this is another thread topic to start and not here?
It integrates multiple ecosystems and consolidates control in one place. I have Wyze, YoLink, TP-Link, Z-wave, etc. all running with automations across platforms.
