I’d like to set up a Wyze rule to automatically turn a fan on for 10 minutes every hour, but only if the fan is currently off. This should run from 9 a.m. to 9 p.m. How can I configure this?
It does not work. It only trigger for 1 time, then it does not repeat.
I have almost the same rule/trigger and it’s been working great:
Can you post a screenshot of your rule?
I’m also not sure what might be holding it up. What does the Rules History show?
Also, if the plug is turned on manually or thru the App at any time between 9a and 9p, the 50m timer will be reset and restarted when the plug is then turned off again.
