I’m not seeing an available update. Did you have to do it manually or ? I think I have beta firmware enabled maybe that is the issue.
The V4 RTSP should currently require being emailed in beta for the firmware. It may also require beta for the app too.
I heard some people were having struggles getting the v4 beta rtsp to work while others were fine though, so I expect an update is coming to fix the issues some people were having getting it started.
I’ve got a few v3 cameras that I haven’t been doing much with after failing to get Wyze Bridge up and running on my HA. Since I had them, I had left one running on my garage watching my driveway because I didn’t have anything else that covered it, and just occasionally looked at it on my phone. Today I just happened to be poking around in the settings and noticed that RTSP was in the advanced options. Turned it on and I was finally able to add my camera to HA. The only oddity for me was that I had to indicate it was working during setup, even though the preview didn’t show anything. But after I added it, it shows up just fine in HA.
@SupportTeam where is the home assistant support? Just offer up some basic API that locally controls the devices like rgb bulbs, switches, etc? I see your rstp work but think of the peripheral! So many more users would buy your products when it works with the #1 home controller. It’s not in competition for your cloud product cause home assistant users where never the ones to but your product, due to lack of support. So why not open a new market of customers to existing products with some sipple code changes. If the community can do it with what’s there already it can’t be that hard.
Welcome to the Forum, @Burninmedia! ![]()
Please be aware that the @SupportTeam user you mentioned is not a designated Wyze employee and that Wyze personnel will be listed in an appropriate Group—such as WyzeTeam—and have a relevant title and profile flair to display their status within the community.
Also, you may be interested in this popular Wishlist topic as a place to post for better visibility to Wyze:
As with any Wishlist topic, you can visit that one to click or tap the Vote button above the initial post and share your ideas and use cases in the comments to show your support for the product and feature request/suggestions that are important to you.
Can somebody update me on the latest status of intehrating Wyze cameras with Home Assistant. I currently have a mix of V4, V3, CamPans, DoorCam, DuoCam etc on my system and use the Wyze app with Cam Unlimited active. I would like to integrate it more with Home Assistant but do not want to lose the current functionality including the AI detection by moving completely to RTSP. Any advice as to the best way forward? I am running Home Assistant via Proxmox on a mini PC. Many thanks
