My Wyze Cam V3 died in the rain
Hello AnnWithAPlan.
Attached is a Word Document for your son-in-law with the instructions for drawing and then 3D printing a Sq Tube Glare Shield aimed at the aim angles best for your situation. Use the values of your chosen horizontal and vertical aim angles in the formulas provided in the doc.
Please give me a like.
Victor.
(Attachment Sq Tube Glare Shield Drawing .docx is missing)
A glare shield? Should be interesting. Thanks, but it says the file is missing.
Hello AnnWithAPlan.
I suspect the lack of a file has to do with the Wyze Forum Fire Wall or equivalent. If you send me an email to victormaletic@gmail.com I will reply with the Word document.
Till later.
Victor.
(post deleted by author)
Looks like rain on the lens. I had that happen to mine. I keep a rubbery thing (those thin sheets that are used for crafts) over the top and back my cam that doesn’t have protection. Another cam died after a storm and I just got a replacement for it last week since it was still under warranty.
I had 4 V3 that the lense cracked,we just ordered new replacement not bad 4 out 80 + cams that we have out in service also there so cheap if they die trash it and get another 1,its not a Sony camera at $1,300.00 +
True. I thought about throwing it away and getting another one, but figured I’d give it a try and see if they’d send me another one and they did. Figured I’d hang on to the broken one in case someone wanted to fool around with it.
Mine are at a 50+% failure rate in less than a year for the ones that are out in the elements, so costly and annoying just to replace.
Yours are under warranty like i said there cheap…there no bullet prof we still have V2 in the elements going on 3 + years
Most of my friends just order the camera on Amazon since it is a wize store and send the bad unit back …takes less than 4 days to get your refund
I bought all of mine through Amazon, too. But the last few times I contacted Wyze directly and I didn’t have to return the old ones. The first one I had problems with was that static, so I was still able to use it but kept the sound off. The second one was with the broken one, where they’d sent the replacement but the picture was blurry. I complained about that and they sent another replacement, which is fine. I just realized yesterday that the blurry one is in focus at about 6 inches! Since I didn’t have to return it, I’m going to set it up where I was previously recording hummingbirds and see how it does there.
Try one WITHOUT a case, your case is probably trapping the water so it can seep in…
16 V3’s all outdoors here, All still working - 100% non-failure rate in 2 years…
I’m surprised they work at all outdoors. All 15 of mine have holes in the back, and you can see the internal electronics.
Two of mine are inside the chicken coops, 2 are in their yard under canopies. One got exposed during a storm and the canopy collapsed, and that’s why I was hesitant about getting it replaced. But they did, because of the warranty. 3 others are under the eves of the house. Only one is out in the elements but that one is covered with a flexible, rubbery flap.
Hello @AnnWithAPlan , @bryonhu , @ipscone , @kae4560 , and @Reefer .
Back in posts #42and 43 is shown a simple helmet that can be fitted over the V3. Using it may prevent the issues raised in your posts. The helmet is configured so water cannot be sucked up by capillary action to any moisture-sensitive parts of the camera. Mine were printed at my local library at no direct cost to me (just county taxes).
Below is a copy of the link in post #42 for the STL print file.
Helmet Mod 2.stl
Till later, Victor.
Hi Victor. I’m pretty sure I downloaded that file when you posted it before. Thanks again. The only cam I have exposed now has a rubber cover that protects it.
The holes should be fine with the rain. It’s all about surface tension. When the perforations are small enough, the surface tension of rain drops make it really hard for the water to get into those perforations. It’s not impossible but it’s much harder the smaller the holes are. That’s how they get the IP rating they get. And it mostly works. I have had 7 Wyze cams of various models out in the direct weather under an open sky and have had no problems. We even had a tropical storm come close here in Florida and they all survived with no issues. Sometimes there are just manufacturing defects or special circumstances that mean 1 out of 500 cameras (or whatever the average is) aren’t up to standard. Sounds like you got the unlucky 1 out of 500.
It is not 1 in 500. For me the V3 exposed to the elements are probably 50% within the year, nearly all by year 2. I suspect the adhesive for the lens deteriorates in the sun and UV. If mounted fully under cover they are OK. It seems more when we get a big temp swing with high humidity and rain. Once the spots form on the inside of the lens when they dry there is a blurry spot in the image that is permanent.
A related thread about the lens being the weak link:
This (lens moisture) is an issue with pretty much all of the Wyze cameras when left out in the elements.
