Hello guys,
Good day!
I was trying to bring all (8) of my wyzecams into one screen of my TV/Monitor and came up with tinypro app. I got that ready and all cams are showing up in one screen…thats fine. But i want to record all these 8 cameras in one screen instead of recording one by one.
Is there a way i can record all 8 cams in one screen? If so, how do you do that in tinypro (or) Is there any software available for that?
Please let me know.
N
TinyCam Pro can certainly record all the streams at the same time, but I don’t think that accomplishes what you want - recording the 8-up view itself. I can’t think of a good way to do that other than a screen recorder…
Yes basically i want all the 8 cameras which i am seeing in my TV to be recorded in one record button and should be able to see the 8 cam in recorded screen…Do OBS work for this?
N
Is the tiny cam app on your tv? Or computer outputted to the tv? If it’s on a computer that’d be easy just have OBS screen capture the window or monitor then record.
Tinycam is on my TV. Am sure there must be a way.
