I know on the wyze app I can view 4 cameras on a page. Is there any other app where I can view all 9 of my cameras on one page. I know tiny cam pro will but I have never had any luck with it. Too many drops. Wish wyze will do an update or is that just wishful thinking?
TinyCam is the only option thst I know of.
Wishlist Topic: Check it out. Also have you tried both Hardware and Software decoding on TinyCam Pro?? Hardware doesn’t work for me but software does (at least much better).
Not the easiest answer but if you load RTSP firmware on each camera then almost ANY normal monitoring / DVR software (Blue Iris, ZoneMinder, LuxRiot Evo, etc.) should be able to do this.
Edit: was trying to remember LuxRiot’s name while @Brlepage got in the same answer. ![]()
