Split View to watch multiple cameras
In the app at some point in the near future will there be an option to watch more than one camera at once? I have several cameras and would love the feature to be added to have a split view to watch more than one camera at a time.
Welcome to the Wyze User Community Forum @EastTN! :man_raising_hand:
If you group your cams in the Wyze App, you can view up to 3 simultaneous live streams on the screen in Portrait and 4 in Landscape when opening the Group.
The only cams that have a multicam view feature currently are the OG Cams with its paired OG PIP feature.
If you want the ability to view more than 4 cams at once, I would suggest an app called TinyCam Monitor. I use the Pro version on Android.
