They did, and it has worked for me
You two are on it! Thanks! ![]()
Woohoo! Thank you! Worked like a charm.
So⦠how do we get ours to work? My app doesnāt update by itself to add another scale yet
Thanks Dave
@Ramrod For Android users, go to the Google Play Store and search for Wyze Labs. Tap on it and update the current Wyze app if available.
Itās not a firmware update, itās an app update.
I believe the multiple scale feature is only available in the beta version of the app. I may be incorrect perhaps someone from Wyze can chime in?
@Ramrod
The ability to add multiple scales to one account is in the production app V2.13.118, you are running an old version of the app. If you go into the play store and it is not updating I would delete the app, reboot and then reinstall it from the Play Store. All your devices and settings are stored in the cloud so deleting the app will not affect anything.
As Jason mentioned above you need to update your app. I would do as he mentioned, delete the app, reboot, reinstall the app.
Thank you Jason for that tip about data stored on cloud, I was reluctant to delete as Iāve got several cameras, plugs and bulbs, everything worked greatā¦. Thanks, Dave
Iāve got two scales in different parts of the house, one called Dave scale and the other wife scale and both have their own device name within the Wyze app,⦠why then does wife weight from her scale show up on my scale and vicea versa? my weight certainly doesnāt fluctuate by 20 pounds and sheās accusing me of using her scale
both devices are on my 1 account, why do they share data across 2 devices? it makes it tough to see any progress on the graph
thanks, Dave
If you both only use one scale each, itās best to just have hers on her account and yours on your account. Beyond that, have you shared the scale and she has it on her app? From my understanding, Wyze uses an algorithm to determine which weight information belongs to which account if there are multiple accounts using a scale. If you have everything set up correctly so there are multiple accounts using each scale, then perhaps itās an issue with the algorithm. I havenāt seen this issue and my wife and I use the same scale, though unfortunately Iām not only 20 pounds heavier ![]()
The whole concept of having multiple scales was to not have more than one account, I didnāt create a āguestā login but wanted a 2nd scale in her bath, so with 2 separate devices the data should be isolated to each scale (Iād think) not cross collecting dataā¦
Wyze wonāt let me open another account within the same house anyway, that was my first attempt when I bought the 2nd scale.
Iāve got 13 separate devices on my account, now that I can have 2 scales I havenāt tried opening a 2nd account again, but thinking that shouldnāt be a requirement from what Iāve read.
I have 2 scales at different locations and would like the ability to see one timeline with one set of data (trends) regardless of which scale I use on any given day. Right now each scale has itās own data/results so I will see 4 consecutive days on scale 1 and then 3 days on scale 2, etc. Is there any way to have only 1 Wyze Scale icon and the app recognizes the correct scale via Bluetooth creating one set of data?
I have a scale and my friend has her own scale. How do we see each others data?
