Multiple chimes for Duo Doorbell
I would like the ability to add multiple chimes to the Duo Camera Doorbell. Currently you cam only use the WiFi chime that comes in the box. I would like to add a second chime so I can have different chimes on different levels of my house
You’re not alone:
In the meantime you have options of using the “Cameras as Chime” feature with certain Wyze camera models (if you’re currently using any of those) and/or using your home’s built-in mechanical chime (if you’re using the doorbell in a wired configuration and actually have a chime installed), though some users have been reporting in the Forum that the latter isn’t showing up as an option in Duo Cam Doorbell’s settings in the Android app, so that still seems like a work in progress.
