Multiple accounts/locations on same iPhone?
Aloha all,
I currently have 8 cameras under my account in Hawaii. I want to install another 10 cameras in and around a home in California.
My question is, can I have all 18 cameras on the same account on my iPhone using the same app? 8 of the cameras will be on one network (Hawaii, Spectrum Cable/wifi) and the other 10 on a separate network (California, Spectrum Cable/wifi).
I understand sharing the cameras, but I need to be administrator for all 18 of them.
Thanks in advance for any assistance given.
There are a lot of users here that have cameras in different locations and countries so it must work.
Yep. And I’ve had a family member with a similar situation, two WiFi networks, different places. You can save yourself some hassle, if you use the same Network Name/SSID and password at both places. Matters not which one, but just same.
Mahaloz for the quick replies. Gonna try this out as soon as I can.
You might want to think about getting some smart plugs so you can power cycle the cameras from a remote location if there is no one that can do it for you at either .location.
Cycle the cameras?
Like in turn the power on and off to the camera. If you camera stops recording or has other issues sometimes just turning the power off then on again will fix the issue. It is easier than running around pulling the plugs out of the wall sockets even if you are at home. I have all ten of my plug in cameras connected to smart plugs.
Oh, okay. Got it. Any links to the product that you use? If possible, want to use items that have proven themselves to work as suggested.
Mahalo’z again.
WYZE sells smart plugs if you want to keep everything on the same app (WYZE). I am using KASA Smart plugs both HS103 and HS105 just because I don’t want all my eggs in one basket. I got mine on Amazon.
Yes, you definitely can. I have three at home and four at the cottage over 350 miles away all on a single account.
As @Sam_Bam mentioned, get some smart plugs. I have the same Kasa HS103s that @Antonius has.
You asked & several replied. I too want to share. I don’t use a traditional looking Smart plug. Yes, these are WiFi and don’t require a hub. Straight WiFi. These are unique and the formal name is Basic RFR2, aka RFR2. Aside from the routine, app-controlled, Alexa-controlled, Google-controlled, manually controlled, and on a schedule controlled, they have still one more feature a RF signal, using generic 433 MHz remote, (such as also linked), you can just press an assigned button to toggle them off and on. The remote I like as 8 buttons <$7 (unheard of). But I don’t simply use these on my Wyze camera. I used them on: lamps, TVs, ceiling fans, coffee pot, fish pond pump, printer, 3D printer, shop vac, computer monitors, porch light, shop lights, cell phone charger, Echo Dots and Echo Shows. Even my cable modem and main router. (Yes, the router.)
These smart plugs have a “Last State” feature. A On, off or whatever last state, position. If it was on and power is lost, when power is restored, turns itself back on. Also stores the schedule 24/7 locally, so does not need cloud connection to trigger a shutdown/restart or start up. For instance, on a cable modem or a router, want to remotely restart it? Pick a time as soon as 3-5 minute in the future or whenever, to shutdown, and 1+ minutes after that to start up, and you in essence have restarted it Another example. Its 5 pm, I want to restart cable modem, set schedule for 5:05 pm shutdown and 5:07 pm start up. Save the schedule and it happens. I have one on my router. All I had to do was create a schedule to shutdown and start up AND add the Last State as “On”. Then when I plugged the smart plug into the power, it read the last state and started, EVEN THOUGH, it had not booted yet to the Internet, it already knew via the Last state was “On”, so it continued to seek an IP Addresses and start the WiFi network.
EVEN BETTER, with the RF feature, I can press a/then generic remote’s button to toggle it on and off, without unplugged it and plugging it back in. (Most routers these days don’t have an on/off switch.)
If you look at these WiFi plugs you ask yourself, where’s the two or three prongs to plug it in. Its an inline adapter. It uses no ground, just load and neutral. I buy 3’-12’ two prong extension cords and cut the cord and attach the male end to the input and 3 outlet end to the output. In a few places the extra bulk of wire is inconvenient, but still worth adjusting. On my TVs, I just cut the TV cord and put the adapter inline since the cord had its own smaller female end going into the TV. Then I have an 8 button remote bedside and couch side to turn off lamps and TV. (They also have a RF version of a wall switch called the TX series and I have them in all walls for overhead lights and use the remote to turn on/off.
If you don’t like the form factor, they have a standard WiFi Smart Plug called the Sonoff S31 or Amazon that has all the features I described EXCEPT RF. No, RF, so I don’t use them any more, but they store the schedule locally.
I buy these from the China factory and are cheaper than Amazon.
See these links. These products use an app called eWelink, that just keeps getting better and better. They also have a webportal for accessing and using the devices.
One of my favorite features of Sonoff devices, you can also control them with NFC tags that you program very easily via the eWelink app. Most NFC to device control programming use third party app like NFC Tools and some backdoor binding method. These are simply program the device in the eWelink app and it works - even with iPhone. Ever used NFC tags? Check them out on YouTube.
Mahalo for the information. Lots to parse out as I will only be on site for a few days. Going to try out the remote outlets locally before I arrive.
Have a great day.
