I just connected a motion sensor to my devices… It is showing motion in the app. Continuously. There is no motion at all in front of it.
I tried deleting and re-adding the sensor, and I tried pulling the battery and replacing.
Any ideas?
Any ideas?
It should show clear In about a minute .
Move the sensor closer to The bridge and see if that Makes a difference
It continued to show motion for over 5 minutes while pointed at a wall in an empty space
Try restarting the camera with the bridge on it
Thanks- I’ll give it a try and see what happens.
That seems to have done the trick. Thanks!
Cool , You’re welcome
