After a short connection outage yesterday, my Motion Sensor trigger was not working. The sensor blinked, but nothing was logging on the App and the Bulb was not triggering. I went thru the normal pairing, the light would not blink red 3 times. I deleted the Sensor but could still not pair it.
Eventually I removed the Bridge and put it back in my V2. I deleted the Motion Sensor and added it back again. Then the pairing worked and my Trigger Rules recognized the Sensor was back
I think this is a scenario where it would behoove a lot of us to take advantage of an in-line battery backup to smooth over outages. And instead of a $50 to $3,000 UPS, all we need is a $10 USB battery charger… Just a thought.
It seems that the recovery process after disruption of power is a little convoluted. I have other devices (electronic) that recover automatically requiring no user intervention… Suggest Wyze investigate the possibility of that with their products.
Definitely understand how it may not be a priority for you, but it has been very helpful for me. As long as they have continuous power of some type, V2 cams continue to record nicely to the microSD card even when the internet and everything else goes down.
And sometimes very interesting things go on when the power is out…
Apparently the App was updated for timing rules when triggering from the Sensor. My bulb was not always turning off as expected after I reset the Bridge. I disabled then enabled my rules. I then had to go in and fix the Clear rule. The update changed my time parameter to a option of Becomes Clear. I selected the Has Been Clear For option and set it where I had it before. Now the Rule and Sensor are back in sync. I believe that the changes to the logic caused the sensor and App to not be in sync with the rule, on top of my having to reset the Bridge which also lost sync with the Bridge.
