Hello, I have a small commercial premises and I would like to know if I can monitor my cameras through any smart TV, do I need some extra so that they can be seen?
Not easily as in an app for smart TV, but it can be done.
Just not easily for those not computer savvy.
Better off buying another brand camera that supports that.
My Security cameras are Not Wyze cams
The ones I use have client software besides the smartphone app. The client software can be loaded on to a PC or other device.
The “Client” software can allow for multi-camera view with multiple layouts. You can put all the cameras on one screen and have some of the camera boxes on screen be larger than others for higher priority cams.
A PC with that client software can feed any hdmi, dvi, etc. to a monitor or TV
As @bryonhu said, doable but not straightforward. You can cast/air play if the TV supports it from your phone/tablet. You can also use Android TV or similar to either load Wyze app or TinyCam.
