Modifications to small wheels on Floor Brush
The current Floor Brush small front wheels have a center portion made of hard plastic while the outer part that touches the floor is of a rubber like material, that keeps the Floor Brush at a certain height from the floor. I have had 2 vacuums in which the rubber part of the wheels breaks off and thus makes it harder to move the vacuum on the floor due to the greater suction since the base of the brush is almost flush with the floor. I was told that Wyze doesn’t have replacement wheels but they replaced the complete vacuum which is not cost effective. Although it is nice for the customers.
For an immediate patch Wyze should have replacement wheels.
A possible fix would be to make the wheels stronger by making the wheels completely of plastic or using a harder rubber that won’t break off.
Can you provide a picture or pictures showing the current wheels and where they failed? Thanks!
