Missing: You Have Reached the End
When panning my camera left, right or up and down a msg of “you’ve reached the end” would appear. Now, it pans a s far as it will go w/o displaying that message. It was working yp to 20-30 mins before this post today. My husband is able to view that msg on his phone but im not. We’re using ios
Check the Wyze app versions on both of the phones you are using, you may be using different versions of the app.
i had this issue an my pan cam was mounted but i didnt push the power plug in flush in the bottom of my pan cam v3 and it rubbed against the mounting area and wouldnt go to left and right… pushed it in and secured it under clips and it worked fine after that.
