Minimum DSL Speed
Because of the Datacap when I was on DSL, I only left my Outdoor Cams on. I set up a rule to turn the others on if Outdoors cams detected movement. You did not say whether you have a Cap. Now with Starlink and T-Mobile, I let them all run.
I have no cap, just slow internet :slight_smile:
I need them to be outdoors, under the eves. I’m planning to use different brand of plugs as Wyze doesn’t look to be reliable. The cottage is some 600 Km away from home. I can’t just hop-on and reset the plug manually :slight_smile:
I am going with the round type and enclose them in a weather proof outlet box.
