Is there a max memory limit for the mini SD that the Wyze cam can handle. For example, can it use up to a 32GB max mini SD card? or 64GB? or 128GB? Or is there no limit on how big an mini SD card can be inserted?
Thanks
Thanks
The supported limit is 32GB although many have reported that it works fine with 64GB or even 128GB cards.
Is the 32GB support still the limit on the v3 cam - or is it safe to use a 64GB Micro SD?
The largest supported micro SD card for the v3 is still 32GB, some have used larger though not supported
