Mesh pro power up delay
I have three mesh pro routers, all hard wired to a 2.5/5/10Gig switch. They work with no problems and the two satellite routers show wired backhaul.
The problem is that if either of the satellite routers loses power, accidentally unplugged etc. the who.e wifi system goes down and takes around 15-20 minutes to recovery,
I do not understand why this happens? The stupid AI support system continues to tell me to power cycle the router which just causes another 15-20 minute backout of my wifi.
Anyone know why these routers do this? Anyway to keep the two working routers up when one satellite router loses power?
I have not experienced this issue at all. I have only seen it when the main router had an issue, then all of the others began to have issues.
Do you have a switch that the Backhaul routers connect to? if so, try changing ports and see if you have a bad port. I had that issue which gave me sporadic issues.
