Does anyone know the maximum watt on the wyze plug?
They aren’t rating them in watts on the spec sheet, instead they are saying they will provide the full 15 amps of a normal household outlet (@100-120 VAC, 60Hz). So that’d be ~1800 watts.
The electrical output for the plug is15A max. If I’m not mistaken, connected to standard 120-volt service, a 15-amp circuit would allow approximately 1800 watts of power before becoming overloaded.
