It looks like you captured a lens flare artifact caused by internal reflection of moonlight. You can tell because Mars is traveling in front of your trees vs behind the trees. Mars captured with a Wyze cam would appear as a very small dot.
Maybe I should call it ufo
Looks cool, but it’s a reflection of the moon in the cam’s lens. You captured a cool meteor @ 0:16 though!
Need to turn Night Vision IR Lights off on that cam.
Thanks at least I caught something,
sure looks like a planet
