Hi i would like to know where i can get the macro lens adapter. I am using an outdoor camera already but would like to be right on top of the nest so i can see the eggs hatch. This is as close as i could go with origional lens.
From other posts here it appears the only way to get that adapter is to buy the bird feeder. Some have gone as far as disassembling the camera and using after market lenses (apparently it is a standard size) and there are also stick on ones you can get off Amazon, but might have to try a few to find one that works well for your setup.
According to a cofounder, it should be available any time now:
You may just have to wait it out and keep checking the Wyze Shop periodically if you don’t want to try a third-party solution. I’ve also recently learned of another vendor’s close-focus lens for aquarium use that’s available without a mount and appears to provide similar focus, though I don’t know how well it might fit Cam Outdoor.
Welcome to the Forum, @timothy.perry75!
This is what I use for my bluebird house
Fielect 3.6mm CCTV Camera Lens… Amazon.com
That, along with a focus ring
@timothy.perry75, in case you haven’t found another solution and are still looking:
