Lost All Of My Cameras To Error Code 90
All of my cameras just went off line showing error 90.
2X Cam V3, Cam Pro 2K, Pan Cam V3, Cam Telephoto
I’ve power cycled two of them but it didn’t bring them back
Any ideas?
edit:
NM…I rebooted the router and it seems to have fixed it
Remember code 90 is allways an internet connection issue…
This same issue popped up for me on 6/14 at 6 am. Power cycling did nothing. Rebooting router did nothing.
FWIW, NOTHING ELSE using my network has had any connection issues during this time.
My Wyze cams have been totally, perfect functional for a few months now, which is rare. Now this. -sigh-
Did it fix it self? Having the same issue
Thats internet code,nothing wrong with cameras you lost your internet and when it came back your router was confused power cycle your router,i have all of mine do a re boot at 3am every day…
If nothing is wrong with cameras and it’s the internet why do you reboot the cameras every night? I can understand the router a little as internet still worked on everything else but cameras. The funny thing is I rebooted my router twice to fix the issue but this morning I get error code 20 & 27 on all cameras. I guess that’s internet too and not the cameras smh
I have the same issue however, it is only affecting my flood light cam. All other cameras are conmected. The flood cam worked fine for the last few months and now i cannot get it to reconnect. Has anyone found a fix to your internet issue? I rebooted the router, still no luck. I am wondering if i need a new/better router for better coverage of my home. Thoughts?
I had to replace my router several months back do to all my cameras disconnecting. A new better router can’t hurt. That way you can eliminate the router causing the problem
