It would be great if you could change the amount of time the camera records when it detects motion or sound. 30 seconds would be great. It would also be great to see a new camera with higher frames per second
Do you realize with an SD card it can record continuously and also record 12 second “event” clips sent to the “cloud”?
This way when it records/reports an event you can look at the “cloud clip” then look it up in your continuous recording.
Wyze needs to work on the interface but it is easily doable now.
Yea I know but it’s also not that easy to slowly rewind it. That’s why I said a 30 second clip from when it detects motion or sound would be great
You could go vote for this
