Arizona here. Fast forward disappeared from my events and then everything went to pot. Now I can’t log in.
Same here. Events keep showing up the disappearing. Getting error codes. Can still view cams even though it’s says they are offline. Super weird this morning.
@HylianSteel Absolutely agree. Wyze needs to offer full local functionality. It’s times like these that I am thankful that I haven’t swapped every light bulb to a smart bulb. Sometimes, there are good reasons to leave some dumb bulbs in place…
It’s also daytime here, so I’m okay for now. If this lasts into the evening/night, it will taking some explaining to the wife.
I’m experiencing the same issues. My Thermostat is my biggest problem at the moment.
I’ve just checked my other stuff - at least Smartthings is still working so my automations for everything else is still ok.
I’m in Scotland
my cams are all back online but events are down
Same here. Can’t even log into the app. Everything is down. Bummer.
Southern Oregon.
Events are back on in England but my V3s are alternating between online and offline - they are all actually online but they show as offline on the home screen.
Ah of course. Was wondering why I couldn’t access events via TinyCam - but the live streams worked fine.
Salesforce is also hosed. Here we go again.
Last week they ended up blaming tech user error. Sure, sure. These have to be attacks on Amazon.
not working here in NYC also, can’t login to app at all
edit: back on now
East coast US - my Wyze app seems OK although one camera is offline.
The Wyze skill in my Alexa app disappeared and I had to re-enable it.
Borked in Seattle. Only one cam working. Lights, all other cams are gone. Luckily my door locks still work - that would be truly scary. Wyze has a major flaw in their system if they rely this heavily on a single internet backbone like AWS.
Same here offline cams that are online…
AWS having widespread issues…
It’s because of things like this that with very few exceptions, I refuse to go “smart” in my house. My “smart” lock does not require internet connectivity to work, only to program. Otherwise it uses fingerprint, code, or regular key. My one smart lightbulb also doesn’t require internet. Once it’s programmed to turn on and off at a certain time, it will work fine unless the power goes out.
Other than that, I have no other smart devices.
Smart door locks that require internet or electricity to work are a very bad idea.
Yes all my cams show off line but they are still working, even the ones you hate, the 4 WCO ![]()
They don’t.
Almost everything working now in England - except those showing offline even they are online.
Even the rules are back and working.
My question is why don’t they have a failover plan for this?
I have just noticed that turning a camera off on the home screen doesn’t really work
I turn it off and it then turns itself on again after a minute or so.
