I am having issues viewing my v4 cameras in live view on the web, My OG cameras are pulling up no problem is this something that other people are having issues with?
Not having the issues with my Wyze Cam V4 or other cameras. the only camera I have an issue with is the Wyze Pan Cam V4 and only when I use Edge as my browser.
Using Chrome and Brave seems to allow the Cam Pan V4 to work.
Also, try moving the problem v4 Temporarily next to your WiFi router / Access Point. If you are still having problems viewing Live View at least you can rule out poor WiFi signal as a cause.
How do you that
To test, if you have a camera like the OP (a v4) unplug the camera Temporarily and plug it into power next to the WiFi router.
If Live View works you know signal weakness at the original location might be the problem.
If Live View still does not work, then other troubleshooting steps should be taken.
