Live Events still being recorded missing playback controls now
Used to always be able to rewind current Live motion events via playback controls but they are now missing. Whenever I get a notification for my v3 cam that there’s motion especially for a Person I could view the event while it’s still Live and even rewind it. That ability is gone now. Was this feature removed?
Do you have Cam Plus or Cam Plus Light?
I pay for Cam Plus. I’ve had it since they rolled it out a couple years ago. The controls are there for all other events except for the Live event that’s currently being recorded. I was always able to rewind to the beginning of the event even though it was Live and see what the trigger was. Now the controls are gone.
Check this out. You are not alone.
@WyzeJimmy
I started another topic before @SlabSlayer pointed me to this one. ( Thanks for the link SlabSlayer)
Another mess up with an app update - By the time I can look at the start of the event, whatever triggered it has long gone.
As soon as the notification arrives I need to look at the video and move the slider to the beginning so that I can go outside and scare foxes away before they cause any damage.
At the moment I cannot do this.
I am getting to the point where I am very apprehensive about installing app or firmware updates because more often than not it seems like they break something.
I really am trying to stay with Wyze - but I am thinking of moving to something else if this unreliability continues. It is almost impossible to use Wyze as the basis of a security system
Thanks! That’s exactly what’s going on. Having to wait until the entire event is recorded before I can rewind to see what the trigger was renders the camera useless for me.
And it is so avoidable - just test updates properly before releasing them.
There does seem to be an increase in problems lately - unless Wyze changed this particular thing on purpose. The reason for doing so escapes me though.
