My cameras came with a rubber sleeve that covers the connection to keep the elements out.
Anyone know what these are called and where I can get more?
I’ve used every search term I can think of but I’m not getting any hits.
Thanks!
Thanks!
Those are Weatherproof Connection Boots and Wyze doesn’t sell them seperate.
Better solution, go to the big box store and buy a roll of Self Sealing or Self Fusing, non-adhesive Silicone stretch tape. They sell it in all sorts of colors. Amazing stuff for waterproofing.
Some day I’ll look for usb extension cables that just happen to have one.
In the meantime I bought a roll of white rubber tape that tears easy.
Thank you very much Slab!
Or try heat shrink tubing/
Hmmm…
I just happen to have a kit filled with those!
Thanks!
