Has anybody successfully connected the Wyze Camera V2 to a Linksys Velop mesh Wi-Fi setup?
Welcome to the community, @Tommynelson1. If you do a search of the forum, you will find a few members discussing Linksys Velop on here.
Please keep in mind that this forum is primarily a user to user community. If you don’t get a helpful reply here, please file a Support Request. Depending on the nature of the problem, rather than use the website link, it is helpful to submit an App Log and/or a Firmware Log.
Thank you for the reply. I have looked at all of the messages referring to the Linksys Velop mesh Wi-Fi. That is why I am asking the question as a new subject.
i am successfully running Linksys Velop. with no trouble i am running 62 wireless devices. this includes 2 Wyze V-2’s, 1 Pan Cam, 4 Wyze bulbs, 3 motion detectors and 6 Wyze sense devices. setup has been simple with virtually no problem. FYI I am also running a ton of Hue, Nest, Wink, TP Link, WEMO, Chamberlain, Ring, Schlage and other devices. Oh yeah, about 6 Google & Lenovo home assistants, 4 cell phones 3 tablets and several other bits and pieces. When setup requires 2.4 GHz, Velop just figures it out. i don’t have to tell it whats happening. I tried several other mesh units, Google, Kasa, etc., but the 5 GHz back channel keeps the nodes talking without any effect on bandwidth. I have a 600 MHz cable speed and consistently get 200-500 anywhere in a 3200 sq ft, 3 level home… hope this helps! I am using the AC6600 3 Node unit. (edited for spelling as can’t see little phone screen lol)
Thank you for the reply. Good information! I will be ordering my Linksys Velop mesh Wi-Fi tonight. I will let you know how it goes.
Hope it helps, I did a lot of checking before I settled on Velop. I think this is one case where buying the best was worth the $$$.
The Linksys Velop mesh system was easy to install. Great coverage throughout my home, including my “shop” garage. All of my Wyze camera’s (6) are working great with this router set up!
Excellent, glad to hear it worked as well for you as it does for me!
I have a linksys velop system which works great with Wyze V2 except during playback from sdcard. Live stream and event capture are great. However, I get an error 42 from every camera everytime I try “playback” from an sdcard in a camera. Sometimes a “unstable network” bubble pops up before the error 42. My test show it does not matter how strong the wifi signal is.
Thoughts?
Yep, I connected my Wyze Cam V2 to my Linksys Velop mesh Wi-Fi setup, and it worked just fine! It was super easy – I made sure the camera was close enough to one of the mesh nodes for a strong signal. If you’re having trouble, I actually got help from loginvelop.com to update the firmware on both the camera and the Velop, and they guided me through making sure the 2.4GHz band was active. Big thanks to them for making the process smooth!
Looks like you didn’t realize that you are replying to a five year old post. I imagine that the OP has found a resolution to his problem by now
