Light strips
I just got my light strip pro today. I know you can cut them to length but can I use the part that’s cut off? I don’t want to waste any of the strip. If I am able to use both strips how do I do I power both of them?
Wondering the same thing. Wondering if you can buy additional power adapters to be able to power extra strips if you cut them.
This should help. It tells you what you need to know.
Not yet. As I said elsewhere in the forum, you can cut them but there isn’t any easy way to use the excess.
