Light shade for Wyze bulb
I would like to see a shade for the lightbulbs. I plug mine directly into the wall, but the light is difficult to look at directly. I tried purchasing a small shade, such as one used with a chandelier, but it would not fit over the bulb.
I have used these with great success.
Fuloon Modern European Style Clip On Droplight Wall Lamp Candle Chandelier Lamp Shade 6 pcs Set (Coffee) https://www.amazon.com/dp/B01GCHDEXE/ref=cm_sw_r_cp_api_i_xQWsEbW2H7QXZ
Do those fit on standard shaped bulbs? They appear to be for candle shaped bulbs.
I’d suggest maybe this plus this.
Thank you. I bought something similar at Home Depot but the prongs did not open enough to grab and stay in place on the bulb. I am happy to learn that these have worked for you.
You are correct I have the same shades but not for the candle bulbs. I grabbed the wrong ones on the web. Too much in a hurry :grin:
You will find if they are for full size bulbs they may be very stiff to open. It’s so they hold secure once applied.
