Window candles?
Would WYZE consider making plug in low voltage window candles? Specifically LED, wi-fi. Many people ( myself) have window candles (12) year round. Battery ones dont last, sensor type dont work ( when the light comes on, the sensor thinks the sun came up and shuts off) and the 110 volt, 6w bulbs cost. It would be nice to program on/off times and brightness, maybe color and blink for alarms such as a break in, etc. Anyone agree?
You can get 5w LED Candelabra bulbs for about $1.50 each and plug them into a smart plug for scheduling. At about $10 each for the smart plugs, it will probably be about the same cost as what a candelabra smart bulb would cost.
At any rate, different sized smart bulbs, including Candelabra, have already been requested in the Wishlist. Follow the link, vote at the very top, drop some hearts :heart: on posts you like, and add a reply at the bottom if you are in the mood.
You could use the sensor type and just cover the sensors and leave them on.
