Light on cam 4V
Can I disable the light on my Cam 4V
Which one? the Spotlight, the Camera Status light or the IR lights, You can disable all.
Spotlight: Go to settings > spotlight > set it to Manual.
Status light: Settings > advanced settings > Status Light
I normally have my V4 Night Vision turned off because I have enough light for color recording. If your cam is set to auto and you have enough light to record color at night just turn the IR lights off:
