Best way to keep the v4 undetected at night
I have my camera v4 installed inside the bedroom window. What is the best night setting with the least amount of light emitting from the camera? And can I turn off night filming if I want? I’m mostly concerned with daytime hours.
Go to settings - Advanced Settings
Toggle Night Vision Mode to Off
Toggle Camera Status Light to Off
Go back to the main settings screen - select Spotlight Settings
Toggle it off from Auto to Manual.
There. That’s how I set most of mine. That will be about perfect for what you want.
You don’t want any lights from the camera trying to shine through a window anyway, it causes a glare and bad picture.
I recommend leaving the camera recording in night anyway, but if you really want to, you can setup a “Schedule” automation for it to turn on and off during certain hours.
If you want to turn the
