Camera light
I have two cameras, one is outside and the other is inside (behind a window).
I had the outside for a bit now. I noticed that in summer that bugs will trigger an event. Then the event turn on the light. I was able to turn it off but I forget how.
I want to turn off the light for the one behind the window as it creates a glare and I see anything.
If a V4: Settings⇾Spotlight Settings⇾Manual
If not a V4, what camera model?
If you’re using a Bulb Cam outdoors (as your topic tag suggests), then it seems like what you’re describing is in that camera’s  Settings âžś Bulb Settings âžś Motion.
If the indoor Cam is a different model, then sharing what that is would be helpful. If it’s something like a Cam v4 or Cam OG, then turning off both the Camera Status Light and the Night Vision IR Lights (both found in the camera’s  Settings âžś Advanced Settings) can help reduce glare/reflection for a camera placed behind a window. You probably want to take a look at those in addition to the spotlight settings (if you’re using a Cam with a spotlight). Sharing more details about your setup and what you’re using will get you better assistance, though.
Welcome to the Forum, @JJMBenoit! :wave:
Thanks. that was the setting on Cam V4!!
V4 and that is the setting!! Thanks
