Just received my 2 Wyze cam v4’s. I have my cams in the window. Did I make a mistake, will the spot lights turn on automatically? Is there a setting to have the spot light not turn on?
Yes you can turn the spotlight off by toggling the slider under the Settings-> Spotlight Settings->Motion…Just toggle the button to turn it off manually… Hope this helps!
Ok I did that but there is a schedule. Will the lights turn on according to the schedule? I don’t see a way to turn off the schedule on that camera in its settings. I don’t want the lights to turn on at all. Motion or schedule. Does that make sense?
No the schedule only applies if the spotlight is on… Since it is turned off it will not apply…
With the spotlight toggled off no action will be taken by the spotlight including any schedules… You should be okay. I am also putting 2 of them behind glass in a window.
Thank you so much. I appreciate your support
Don’t forget to turn off the IR lights if you have night vision turned on and also turn off the cam status light if it is going to be behind a window.
You’re very welcome and yes don’t forget to do what @Antonius mentioned about turning off the IR lights as well and you should be good to go.
I was under the impression that turning IR lights off wasn’t an option on the v4. Am I mistaken?
Yes they are behind glass. I have all lights off. If I have any issues with this I will post back here about it. Thank you
