How to delete the schedule spotlight torn on. I put the schedule in that area instead of the rules section to turn on the lights on with the socket. I looked under the spotlight setting and there is no delete or to turn it off permanently.
Thank you in advance
Welcome @smittyj26
From what I understand, you modified the schedule from Sunset to Sunrise, to something else. Sounds like you don’t want the spotlight to function via that process, but rather a rule.
So you basically turn off the Motion Toggle located in the “Activate when Camera Detects”. This will leave the spotlight off.
Then you can utilize rules to turn the spotlight on and off.
I did turn the motion off hoping that would stop the light from coming on. Thank you for the quick response!
