LED lighting causing video quality issues
I have the wyzecam OG in my in my shop. I have LED lighting and it causes lines in the video. Is there a setting on the camera that i can change that will fix this? Or does anyone know what i can do to fix it? Thanks
No setting, your best bet is to try repositioning/angling the camera so the LEDs are not shining into it (even if you can’t see them in the picture, shining from above or at just the right angle will still do it, LEDs have very directional light). It may be a matter of just tilting it a few degrees.
Ok thank you for the advice. I will try this
