Hi all,
I’ve installed a new wyze camera in a CNC enclosure, and I have LED lights in the same work area.
There are very pronounced rolling black lines (see attached) on the feed when the LEDs are on that disappear when the LEDs are turned off.
I’d like to use both products - is there a way or setting to mitigate these lines?
Thanks!
https://www.google.com/search?q=led+lighting+causing+bars+in+video&oq=led+lighting+causing+bars+in+video&aqs=chrome…69i57j0i546l3.30769j0j7&client=ms-android-att-us-rvc3&sourceid=chrome-mobile&ie=UTF-8
The above link is the reason why you have the bars.
The V3 does not have an adjustable frame rate so your only fix would be to change the LED lighting or it’s power supply.
However the frame rate does change from day/night vision from 20 fps to 15 fps but that may not help and will cause the camera to switch from color to B/W video too.
