Latest release breaks all camera interaction
After installing latest version 2.44.0.6 - Log ID 1132135 submitted - clicking on individual camera in group list takes you to last still shot, at that point the camera cannot be interacted with, no playback and transfer speed indicator drops to 0.0 fps - Have gone back to latest beta 2.44.0 (4) which is working fine - does this need to be posted in beta feedback forum if the problem is only in the release version?
If lthe beta branch app works, but the production branch doesn’t, it would appear that the issue is with the production app. Have you contacted Support yet about this? Thank you for submitting a log, but that’s the first step in a multi-step process that the user needs to follow to get assistance. As the received email after submitting the log states you need to contact support separately and provide them with your log ID number so that a support ticket can be created and assistance given to the user. A support ticket number is different than a app log number.
https://support.wyze.com/hc/en-us
Agreed. Same problem with latest release as of yesterday.
The create a ticket link is having problems. Any suggestions?
Glad someone else is seeing the same problem
All my v3 with cam plus are doing that. I have now found by going to setting - the gear in upper right corner - in that camera and then back to camera it will work. Shouldn’t have to do that but it is a workaround until something is fixed.
Do your cameras turn off notifications all by themselves?
Nope, notifications are behaving, however that may be because I am staying with the beta.
Ok. I’m using 2.44.0(6) version.
The notification problem has been going on for months. I will go to events and no cameras are selected so I select them and close the app and reopen app and go to events and there are no cameras selected. Kinda defeats the reason to have cameras if they don’t notify or freeze frame.
I’m glad you found this temporary fix because I was about to go off. So sick of these things happening after updates, it’s like they don’t test their own dang products sometimes.
There are large grey bars above and below each camera view now also, not sure what that’s about
Are you using the latest beta? I’m about ready to try the beta if notifications stay on. I missed a very important mail delivery that had to be signed for because the notifications had turned off and I didn’t hear door bell.
Am using 2.44.0 (4) which is the latest beta available in TestFlight - Notifications appearing fine here
Also if you are on the freeze frame you can use the - more - turn off and when it powers back up it works. At least for me it does.
Ok. Thank you
Also have found that leaving the app running in background the events stay on. It’s only if you close app and reopen or reboot iPhone that cameras are unchecked in events.
We have the same issue. This is super annoying. The workaround works, but, this really needs to be fixed asap.
I agree. When cameras or the app or cam plus don’t work it makes you wonder
The update just now fixed the freeze frame but notifications still doesn’t stay checked. Come on wyze
Please make a post here for better Wyze visibility:
Wyze app hotfix - Released 8/3/2023
Submitting an app log and posting the Log ID in the announcement topic above will also help expedite a fix.
Do you want a log on each camera? That’s 7 cameras.
The problem is when you open the app in Events it ALWAYS unchecks every camera. Once I check each camera notifications is on and will stay on if I leave the wyze app running 24/7 in the background.
One app log should do. Go to your Events page with the issue. Then tap Account > Wyze Support > Submit a log > Wyze App & Services > Events > describe your issue > optionally attach screenshots > Submit
The app notifies me that I have events to view and you go, and the vents are not there. You can refresh the cameras, but some of the events are still not there.
