I had a Cam v2 fail on me the other day after a firmware update. It keeps responding “Cannot connect to local network”. Power cycled the device and still no luck.
Did a manual firmware update just in case the network update had any issues and still no connection.
At this point I figured perhaps it’s a legit hardware failure so I went out and bought another v2 Cam. Installed on the network with no issues. Cameral functions fine. It prompts me for a firmware update so continue and after the update same issue… “Cannot connect to local network”.
Seems the latest v2 firmware is rendering all my v2 Cams useless. ![]()
