Wish me luck I’ve just opened my boxes of the cam v4 and I’m setting them all up this evening… hopefully I’ll get it right… I’m blond I may need some extra luck tonight… ![]()
If anyone has any suggestions please share if you don’t mind… xoxo thanks
It is best if you can mount outdoor cameras under a gutter or some kind of awning to protect from rain and direct sun.
Welcome to the Wyze forum.
Take your phone, make sure the wifi is on and walk around to the locations you plan on putting your cameras after you set them up and see if you have a good wifi signal. The V4 works on the 2.4GHz WIFI band only.
Also, when mounting keep in mind how you will be getting power to the v4.
Hey nothing wrong with being blond! My old boss was blond and she was the smartest boss I’ve ever had, and technical too. ![]()
I would recommend setting up your V4 near your WiFi router to make everything go faster. After it’s setup then you can move it outside to where you want it.
